Simple Swap Headlight Bulbs?
mac777daddy
Are there any headlight bulbs available that are bright white that will work in the factory headlight housing? A bulb that will make a difference. All I want to do is swap the bulb out. I still have all stock headlight components and the headlights are yellow'd and not very bright. Thanks!!
Are there any headlight bulbs available that are bright white that will work in the factory headlight housing? All I want to do is swap the bulb out. I still have all stock headlight components and the headlights are yellow'd and not very bright. Thanks!!
If you're just going to upgrade the bulb, then I recommend the HIR bulb upgrade. Just a little trimming to the bulb is needed. Here's a thread; http://www.toyota-4runner.org/4th-gen-t4rs/69166-high-intensity-infrared-hir-bulb-install.html
and more info here; http://www.toyota-4runner.org/4th-gen-t4rs/99221-best-replacement-plug-n-go-headlights.html
Tx470
