Skunk
slyangel9
This last weekend I was driving through CT. w/AC and recirculating on and yet a smell of a skunk came through. Has this happened to anyone else?
You sure it wasn't the sulfur smell of the exhuast you smelled? I've never been honored with a skunk spray, so I wouldn't know what they smelled like.
That is weird. I have many skunks where I live and when I psuh the recirculate button, the smell is gone within seconds. The only smell that I get is the sulphur smell like sharp4runr said.
In other cars I've had, I've experience a similar problem. Then again, I lived in the midwest, so dead skunks were everywhere...
How bad was the smell? Was it extreme or barely noticeable?
In other cars I found out it was b/c even when you had the A/C on recirculate, a little bit of air was still coming in from outside. That kept the smell perpetuating. Also, if you let too much "stink" get in before switching the A/C to recirculation mode, the stink may stick aroung longer. Lastly, i found that the stink (like that of cigarettes) stays around longer in cooler/colder weather.
If it's still around, try spraying either mild-smelling cologne, body freshener (if that's what it's called), air freshener, or febreeze under the dash on the driver's and passengers side of the Runner while you have the A/C running on re-circulation mode...I found that helps overall and keeps the car fresh for a few days.
increasedc
