Slight steering wheel vibration
skag1T
I replaced the OEM tires on my 2018 4Runner SR5 (1,500 miles) with a set of Nokian Rotiivas. The shop did a good job at balancing the wheels, and I went back a couple of times to fix some minor steering wheel vibration that I would experience at highway speeds.
At this point, I still see a slight vibration in the steering wheel around 65mph. If I keep my hands on the wheel, I don’t really feel it, but if I take my hands off the wheel, I can see the vibrations (about 1/8 of an inch each direction). Again, this only happens at 65mph +/- 3-4mph.
The shop told me they did the best they could to balance the wheels. I went back 3 times, they reset the tires, re-balanced them, etc. – were very helpful.
I am a bit OCD about this :D , so I want to ask the community – what are your thoughts about this ? I also understand that some 4Rs have an issue with steering wheel vibrating. I don’t remember if I experienced this with the stock tires or not – probably not.
Can this be corrected further ? Is this an issue ?
road force balancing helps, but im guessing most 4runners have the vibration whether the owners recognize it or not.
Bad vibrations!!
Here is what fixed the problem for me...
After 7 or so attempts and going through three sets of tires, vibrations were still present.
What fixed it for me was performing Roadforce balancing and making sure the force measurement for each tire was 15 pounds or less. Two of the tires in the third set were at 25 and 17 pounds which was not good enough so once they got all four to 15 pounds or less, no more vibrations.
By the way, the first two sets I tried were Falkin AT3W... loved the look but no luck balancing. Switched to Yokohama Geolander AT015 which are about 4 lbs lighter per tire so no hit on MPG. Hope this helps!
[MENTION=9504]4Rman[/MENTION] Thanks you will look into Roadforce balancing.
[MENTION=147480]aelarson[/MENTION] Thanks, I did search, that's why I was aware of the issue ... appreciate the links though
