Small Hole in Lower Ball Joint Boot
jnance50
So after my lift yesterday, I noticed on the lower ball joint on the driver side is leaking a VERY tiny amount of grease from the middle of the boot. I mean, it's almost like you took a sewing needle and put a hole in it.
Question: What should I do? I feel like if I take it in for warranty work they'll just blame it on the lift - thought it is an option. I could let it go until the joint needs replaced, try and put a dot of RTV on it to patch it, or try and replace it myself? What would you guys do?
Also when I was doing the lift, my driver side away bar link was leaking grease as well, but it seemed like it was coming from around the edge, not a hole. Maybe it got pressed too hard or something - ideas?
