So nobody knows how to install a CB ?
4Runnin Eddie
The only thing I need to know is where to plug the red wire (positive) into, I do not want to plug into other wires, only the fuse box but where in the fuse box.. Please help.:awais:
Thanks King, so where does that thingy plug into? which fuse space ? How do I know which s a ignition fuse ? sorry about all the questions...
That's a big 10-4. I'll get ya on the flip side at the eat and puke. What ya haulin?
I only run the cb on trips so lay it around. You got a good spot to mount it?
What you do is pull the ignition fuse and put it into the first slot on the adapter, then put in a 3 - 5 amp in the slot where you crimp the power wire to, then plug the adapter into where you pulled the ignition fuse from on your truck. In my case it was under the dash on the left side of the steering wheel. On the back of the fuse cover is a listing of each fuse.
My 4Runner is an 07, so it might be different for you. I'll take some pics tonight of where I put it. It's really nothing special just I bought some wall hangers and jury rigged it to hang from my cup holder. Being a new truck I didn't want to drill any holes for a fixed mount yet.
Just go to Radio Shack and buy a cigar lighter plug for about three bucks. Crimp the red & black wires into the appropriate spaces and - Voila! - you can plug it in as you would a cell phone.
:awais:
Sounds impractical to me. Not a bad idea I suppose, but for a CB a solid ground is important. I'm not too sure if engine noise would come through that way, and having to remove it to power a phone seems like a waste. Most who want a CB in there vehicle I'm sure would much rather have it as close to hard wired as possible. Even with my set up I can remove it in minutes if I needed to.
Here are pictures of my less than professional install. My coffee cup fits perfect. With this set up it's very stable as the rubber coated hooks cradle and secure the cup perfectly.
Hey King I had a similar set up as the one you did, but I like your set up much better. I even went as far as using Velcro on the back of the console, but the radio was behind me so it was hard to use if I had to change channels or turn the radio down if it got too loud. So I scrapped that idea, I went with some S hooks and hung it the cup holder, similar to your set up, but that did not work well either
I thought about Velcro too but after it not working out so well in my Camaro in the past I didn't even consider it this time.
I got the wall hangers from Home Depot, as well as the small bolts and washers. I only have to reach the slightest bit to turn on/off, squelch...but everything is well within reach. I use an external speaker as you can see which is better for hearing, and with the speaker bracket on it fits right into the cubby next to the outlet. It will come out on hard cornering sometimes but not very often, and seldom do I take a corner hard.
Here are some pictures of the commerial radio that I use for GMRS. I screwed directly into the plastic trim and wired the radio directly to the car battery. I chose the passenger side because most of the time I'm usually driving alone and it doesn't get in the way of my legs. :D
* The mic is missing in the pictures.
Lowpro, nicely done. I tried mine on that side, and couldn't handle the reach. What kind of range do you get with that GMRS setup, and what type of antenna do you use?
Does anyone know which fuse is the ignition fuse on a 87 ? The fuse box is on the left side near the brake but it doesnt say which is which fuse.
ahem, thats choke and puke! :D
The reach is not that bad, I don't think. Here in Los Angeles I use the Verdugo GMRS repeater that is located above Glendale. The repeater sits atop of a 3,000 mountain and covers pretty much all of LA County. I use a 1/4 wave antenna (6in tall) on a mag mount. I haven't found anybody that I trust enough to drill into my roof. :D
www.socalgmrs.org
6" tall? I don't know that much about it. How different is the CB from GMRS anyway?
I too wont drill a hole through the roof, but the cable through the back hatch leaks some when I wash. I just put a towel down. It's an inconvenience, but not that bad really. Fortunately it doesn't rain much here.
I run the coax cable down the rear drivers side door, it hasn't leaked up to now. CB is a dying sport, IMHO. With GMRS* you can use commerical grade equipment and use repeaters. Everybody has their own thoughts about GMRS and CB, I'm sure a hammy will step up to the soap box.
Where in So.Cal are you?
*You must have a GMRS license ($85 for 5yrs and covers your entire family = $1.50 a month)
I live in Tustin, work in Gardena.
I'll have to check out the rear drivers side door. Any problem with the cable fluttering at highway speeds, or is your antenna just above the door there. Maybe I should just ask where you put the antenna.
I'm intrigued with the GMRS. I'll be looking into that now, thanks for the enlightenment.
