AntleredRuin
Yeah if you have a valve cover gasket leak so bad you can hear vacuum while in the car, and freeway driving no less, then I'd think you'd have bigger problems than that.Yeah you raise a good point.
My booster DOES work and no obvious leaks. I just cling to it since it's the only thing I can do without ripping into the intake manifold. Lol
I am missing that bracket that pressed against the check valve. I'm gunna try and scope tht up at the junk yard.
I do have an oil leak I think it's coming from the half Moon on the driver side. But I could never see if anyone had a leak bad enough to have an audible leak coming out of there.
I'm trying to hold off on the valve covers for weeee bit. Starting my timing belt job tomorrow, I got a laundry list of stuff to do. Gunna take me at least a week to get it done.
Sent from my Pixel 2 XL using Tapatalk
That being said, curious as to why replacing the oil fill gasket mostly fixed the noise for a short period of time. I wonder if the valve covers (and maybe the intake manifold) really are that loose, and the pressure you exerted while pressing the new fill gasket on slightly sealed the valve cover down a bit more into the current gasket? Then after a few miles it lifted again?
For shits and giggles, try just getting in there and tightening all valve cover and intake manifold bolts you can find. Be careful, though, the valve covers wings are weak. Those bolts need to be barely more than finger tight.
Have you replaced the PCV?
The intake is a bit of a PITA, but much less work than it seems. Or well, easier than it looks at least. Just a lot of little steps. Just don't break an injector off in it while taking it off. I had to use some super long forceps to get the tip out of the valves. That was a pucker moment :wow:
