B
bonedoctor
Guest
Got the pics back from the TRD exhaust installation. The first few show the old exhaust after I had to first take a cutting torch (my O2 bottle ran out when I was just about through) then an air chisel to get off the vehicle. For whatever reason, the nuts holding the front and rear sections together had been welded. You couldn't get at them with a hacksaw, an air chisel, etc., so I was forced to cut the pipe behind the large muffler. You can see where I tore up the nut (but couldn't get the damned thing off) with the air chisel (pics).
There's a pic of the rear of the vehicle with the exhaust completely gone (I had the typical single, out the back tip with a Valor tip in place) and with the dual outlet system installed.
The system had to be modified a little to get it to fit. About three inches of pipe had to be removed between the small front resonator and the large muffler (pic) and the front hanger had to be flipped 180 degrees so that it would match with the factory frame hanger (pic).
The passenger side fit without any mods. The driver's side fit nicely around the spare (I thought for sure I'd have to loose the spare with the XREAS option on my vehicle). The hanger did have to be repositioned a little to match with the new hanger mount on the frame that was supplied with the exhaust.
