Something weird happened to my 4WD
tonybaloney
so i have a v6 2006 runner and switch between H2 and H4 regularly and have never seen this happened before. i also did a search and couldn't find anything.
so as i was driving today (around 50mph), i turn the knob from H2 to H4 expecting it to engage after 3-5 blinks. there was a very very VERY slight curve but i didn't expect it to be a problem. i only had to turn my steering wheel about 10 degrees to make the curve. so the 4WD didn't engage. i would expect it to continue blinking with the green 4WD and yellow center differential lock light but no! this time, it started blinking 4WD+CDL+4LO light. the blinking frequency is twice as fast. i couldn't just pull off the road so i continue to drive for another 15 miles since i didn't feel anything wrong even with the lights blinking.
i was able to finally pull off into a parking lot. the car felt normal going straight. it felt a bit tight when i was turning. it felt exactly like how you try to switch from H2-H4 and turn at the same time before it was engage so i wasn't too worried about it.
so with the 4WD+4LO+CDL light still blinking, i turned off the car. when i turned it back on, the VSC light was on! the 4WD+CDL was blinking normally now like usual. with the VSC light on, i put the car into D and it won't move! i tried it a couple more times and it still wouldn't move. i didn't want to just press the gas petal in fear of breaking anything. i was freaking out at that point. eventually, i put the car in R and the car moved and the VSC light went off. i have played around with the car, it goes from H2-H4-4L okay. CDL seems to be working as well.
has anyone seen this happen before? Should I be worried? sorry about the long post.
If it is having trouble changing from one mode to another, put it in neutral to take the stress off the driveline. Turn the nob back to the previous position and try again.
personally, i wouldnt engage h4 if i was going over 35, 50 just seems a bit much no matter who or what says its safe. id rather avoid something like u had allthough im sure it can happen at lower a speed, whether its so or not, it just sets my mind more at ease.
i guess my main concern was the fast blinking about 4WD+4LO+CDL lights. i didn't find anything in the manual talking about that and didn't see anyone on the forum mentioned about that before. Other than that, the car is driving normal right now... everything is engaging after 3 blinks...
I find that I have the most problems with my 4wd if I'm either Noe moving or my wheels are angled at all. For 4low I never have a problem unless I'm going from 2wd to 4lo never from 4hi to 4lo.
Why are you switching between 4Hi and 2Hi frequently? You really don't need it, especially if you are driving on pavement. Driving in 4WD while on pavement isn't great for the drivetrain.
it was raining pretty hard so i thought i would lubricate the system like the manual said to. if i don't ever use 4wd on the pavement, i'll probably never use it since it doesn't snow here. i think the same goes for most of the 4runner drivers. i feel safer going 80mph in the rain with my 4wd instead of 2wd :D based on what i've read and was told, there is no harm to the drivetrain using 4hi on the pavement. if that's the case, how are the V8s doing it?
80 mph in 4H mode? I consider 60 mph tops due to weather/road conditions alone. It is usually nasty when I use 4WD. Would going 80 mph in 4WD cause damage or perhaps dangerous?
not sure why going at any speed at 4H will damage the system considering V8 has full time 4wd. unless there is any major difference between V8 and V6 power train...
He goes 80 in the rain because he is out here in CA!!!
It's a 4th gen. It is perfectly fine to drive in 4WD high while on dry pavement -- that's what the Torsen center diff allows. Just keep the center diff unlocked.
And our V8s are in 4WD all the time.
Hi All, apologies if this is a known problem but for some reason my 4wd and diff lock light stays blinking all the time. I must have pressed it by mistake now I cannot get it off! Anyone help please? I have the 2002 3400 V6 4 runner.
Cheers
Mcd
Cheers
Mcd
2002 is a 3rd gen. You might have better luck posting in the 3rd gen forum.
