Sonoran Steel #7/ Tundra-OME lift question.
NateDawg
I can't afford the SS &7 lift right now. If I were to just get the Tundra TRD springs, OME 890's, Tokico Trekmasters, and the 3/8" spacers, would allegedly recieve the same amount of lift as someone who has the whole kit installed? I realize everyone gains a different amount of lift, but the final height would be the same would it not?
You should end up with about same amount of lift.But with any lift above 2" you should also include a diff. drop spacer to keep your CV's happy.
At trdparts4u.com it says that the OME coils can only be installed with the OME Nitrocharger shocks. Front or Back coils. What gives. I had plan to run the Tundra's up front with the 890's in the rear with Tokico Trek>Masters all around.???? Wuold it be okay>?
