Sony XAV-AX100 Installed (Photos & Short Review)
[MENTION=293182]LinuxHack3r[/MENTION]
I'm thinking of buying the same Sony HU as you and wanted to confirm if there items were purchased by you as well:
- Sony XAV-AX100
- Crux CS-TJ20 Wiring Interface
249CSTJ20
In Stock
$47.93
- Metra 95-8210 Dash Kit
120958210
In Stock
$7.98
- Metra ISOPK Screw Pack
120ISOPK
In Stock
$0.93
$1.06
Eh. Sorta. If you go through Crutchfield they included all that needed stuff for free. It depends on if you have steering controls, JBL, and or the Urban Runner package. That list looks right...but I had the "most basic" installation as I don't have steering controls and I don't have JBL. I just had the "base" audio system and nothing more.
So that could be right. Again, I'd go through Crutchfield, select your vehicle/trim, and go by what they say.
Also, if you purchase gift cards through "Raise" (listed previously), you can save big bucks!
Ok, thanks. I do have JBL and steering wheel controls so I needed some "extra" stuff. I'll definitely go through Crutchfiled support and Raise as you suggested.
Thanks! That’s the type of camera I was planning to buy. Are you happy with it so far?
It works just fine, especially for the price. Night vision is fine. The only thing I don't like is that it is slightly off center in that location which in reality is an issue with most reverse cams.
[MENTION=97029]Maxie[/MENTION] I'm am asking you this question since you have JBL.
1- Sony XAV-AX100
2- Crux CS-TJ20 Wiring Interface
249CSTJ20
$47.99 (cheaper if you buy it as part of a kit, otherwise $89 if you buy this unit by itself)
2a- Metra 95-8210 Dash Kit
120958210
2b - trim piece
$7.98
2c- Metra ISOPK Screw Pack
120ISOPK
$0.93
Note: Item #2 includes 2a, 2b, 2c as part of a kit they sell.
I honestly don't remember what I got, other than following Crutchfield's recommendations. I know I paid for the wiring service (worth it) and there was a additional integrated harness for the steering wheel controls. Other than running a wire to the reverse signal wire in the fuse box near your left knee, it was pretty plug and play.
Edit : I think what you listed above looks right. There was definitely a box thing like that Crux.
Thanks dude but if you happen to find out any more details, let us know. Sounds like you might have the correct template for the JBL folks like me.
Thanks, yeah, I was wondering if it would appear off center in the screen image because of that position. Still a super clean way to install for sure.
Ordered everything, should be here by Friday for a weekend install. Looking forward to a decent sound and android app usage.
edit: nope, not friday but prolly Monday of next week.
So...photos!
Looks great. Works great.
Why is your 4WD switch in between 2wd and 4HI? :biggrin2:
Looks really good, I've been contemplating the switch to a Car Play radio for a while now. I use my iPhone for nav all the time so it would be nice to have it on a bigger screen.
+1 for the recommendation to use Crutchfield. I've now installed three radios I bought through Crutchfield. All installed without a single issue by following their instructions. They didn't have the Ready Harness service when I bought my last radio, but I will use it for sure next time.
Well now that I thought I had everything sorted out, I’ve noticed my HVAC display screen no-longer has backlight, all the switches do. Just the screen is not backlit. Unfortunately the truck is new to me so I dont remember if it worked prior to radio install, but I’m fairly certain it did.
I'm in the middle of this system installation and the sound it produces is simply awesome! The bass hits hard and the highs are really high. I have the JBL system with RDS so the sub in the back has come alive!
So now I've discovered that the center dash speaker is blown. I've removed it in the hopes of finding a replacement. Someone said that it is the same speaker as the upper door speakers, including the frame. Let me what options are available for this spot.
Can i ask someone to post up a picture of google map and other android apps on their screen please? I'm assuming that I can see some of these apps on the HU but so far I'm not seeing anything. I should read the owner's manual some more!
I'll look through the EWD to find a reverse light circuit near the dash area to tap into. I don't have a camera yet but figured on doing this while the dash was all apart!
Common for them to go out when pulling the hvac controls.
if you search you can find the part numbers needed. I would buy extra lights too. I had more go out when I replaced them.
Dealer printed me out the part numbers for the hvac lights, however they only had 1 in stock. Luckily half of it turned back on after a couple finger taps =D. Your right though, now my rear window button light doesn't work.
If some of the lights came back on by tapping with your finger you most likely bumped some of the connectors for the lights during your radio install, I would check all the connectors to ensure they're making a good connection, some may need to be unplugged and or untwisted and reconnected because of dirt/corrosion and or vibrations causing them to develop a poor connection over the years.
I just want to chime in to say Crutchfield truly is awesome. I bought a refurb Kenwood DX 9702s from them in 2016 and when I brought it Bestbuy for installation (along with a backup cam), the installer told me the unit wouldn't turn on and was defective.
Crutchfield did not have any other DX9702s in stock since it was last year's model. They replaced it with a DX9703s brand new!
Only con with the Kenwood is the lack of a volume knob for me.
After seeing OP's setup, I'm gonna replace the cigarette lighter by the gear shifter with a dual USB port. I currently have the USB cable coming out from behind the glovebox.
Sent from my SM-G965U using Tapatalk
Nice post!
With that service from crutchfield it would save me about $600 over what a local shop quoted me if I installed myself.
They have a dual USB with a voltmeter on Amazon that I have. Easy to install too. There's a write-up my build thread.
some update from my install, in no particular order.
- this is truly a plug n play system once you order the stuff that I mentioned previously.
- I had to update the firmware using an USB stick, no biggy.
- Neither CarPlay, nor Android Auto will work wirelessly. This isn't a big deal for me but maybe for some folks. I spoke to a Crutchfield tech support.
- My plan is to get one of the USB plugs, maybe a circular one, and place it permanently below the hazard button. This will be a dedicated USB plug only for CarpPlay or AA and/or charging duties. I'll leave the current USB/cig lighter option for charging duties.
https://www.amazon.com/dp/B072KGMJ5...colid=AB4XARP3YFL5&psc=0&ref_=lv_ov_lig_dp_it
- I used both CP & AA yesterday and I gotta tell you that CarPlay GUI is far better than AA GUI.
The Crux kit also has a connector for connecting your factory OEM rear view camera to this Sony HU. FYI. It really is a great kit and totally worth the money.
I have replaced all speakers with Rockford from amazon, including the rear sub and it sounds amazing.
Would you mind providing more info on this? I have an 06 limited with OEM rear camera and just installed this HU with the Crutchfield kit. I noticed the "OEM Camera Power" wire and did not connect it for now as I didn't know where to wire it up to. I get "No signal" when I select rear view camera in the HU. If I just wire the camera to power will it work or is there a separate harness I need to order? Is it 12V? Thanks!
usedautopartspro
