Sounds like my windows are open
Burnzy
This has been going on for a while. When another vehicle drives past me it sounds like I have a window cracked open. I mean the sound is very clear and loud enough for me to try to roll my windows up even though they are up. I have inspected the door seals and I haven't seen anything unusual, they appear to be in good shape. Is there something less obvious I am missing or need to check? Also possibly related, I noticed that freezing cold air is coming through the front drivers door. If I put my hand against the door while driving it feels like freezing outside air is seeping into the cabin. Ideas?
sounds like you've done a pretty good job of diagnosing it as a door or window sealing issue....
you could test the door seal by putting baby powder on it and then shutting the door, open the door back up and see where the powder isn't sort of thing..
window seals are a different beast... 2003-2009 corollas a prone to faulty window seals that were too small and cause massive amounts of interior noise. I know because I own a corolla in this range... the solution there from toyota was a recall on the window seals. something to think about... this thread talks about the corolla issue: Need to replace my rubber window channels - Toyota Nation Forum : Toyota Car and Truck Forums
good luck
