Southern Style OffRoad Group Buy - 5th Gen 4Runner Rear Bumper
Status
Not open for further replies.
Man I wish I wouldn't have missed this group buy :doh:!!!!
Kevin these bumpers are awesome!!! After wheeling with Doug this past weekend in Tunica I'm itching for one. Nice work :thumb: [MENTION=110183]SouthernSS[/MENTION]
Front slimline bumper shipping weight is 90lbs...this ships FedEx ground
Rear bumper shipping weight varies between 190-265lbs depending on options. This ships freight on a pallet
Are the accessories on the swing arms interchangeable? As in, can I order a bumper with a ladder on the driver side swingout and swap out to a jerry can holder down the road if I want to?
do you have any updates on how the parking sensors will be mounted?
Yes actually. We were playing with this last week and came up with a pretty simple solution I think. We measured the precise diameter of the plastic holder and counter sunk the hole just slightly larger so the plastic hooks can set. Then you just slide the actual sensor in from the back and it holds everything tight through compression. This was in bare metal, so we'll make the hole just a bit larger .006" to compensate for the average thickness of powder/paint.
My SSO rear bumper came in today! Kevin and the crew over at SSO are top notch. Just a few more days with the powder coater until we can get this bumper installed. So juiced! Head over to my build thread to see a bunch of pics of the bumper raw.
@RIDE
I am 8th on the SSO rear bumper list, so mine will be arriving in the not-too-distant future. :whoo:
Curious to know, if due to the weight of this beautiful SSO rear bumper (~265lbs with dual swing arms + ladder) are you or did you change rear coil springs? If so, what did you go with?
I currently have SAW 1.5", but concerned that they will experience some notable sag with 265lbs of steel added.
My research is leading me toward OME 2895e or 2895.
Thank you for any feedback!!!
Yes actually. We were playing with this last week and came up with a pretty simple solution I think. We measured the precise diameter of the plastic holder and counter sunk the a hole just slightly larger so the plastic hooks can set. Then you just slide the actual sensor in from the back and it holds everything tight through compression. This was in bare metal, so we'll make the hole just a bit larger .006" to compensate for the average thickness of powder/paint.
Absolutely beautiful.
Sent from my SAMSUNG-SM-G935A using Tapatalk
What size drill bit did you use for this? I'm trying to mount the parking sensors on my front bumper, and need help with this.
Sent from my XT1254 using Tapatalk
Wasnt a drill bit, but a laser that cut it to the thousandth of an inch. The three holes in that plate are just barely different sizes to test for the perfect fit.
51/64 bit is too small, 13/16 a little too big, but thats all you can really do when you dont have a laser to get it just perfect. Id start with a 51/64 and woller (sp?) it out as you need. You'll also need to counter sink it a bit on the back side so the plastic hooks can set. Thats in 3/16 though, 1/8" plate will be a whole new story.
Is the rotopax mount something I can add later? Or can I still add it?
Could you email me with your name or order# & I can check it for you. Email is [email protected] We can add the Rotopax mount now for sure. Later would depend on a couple of things.....need to see your order before I can correctly comment on it.
I think [MENTION=78318]RiDE[/MENTION] is the only one to receive the bumper so far???
*Peers longingly to front of line, sighs... steps back in line*
We ordered our's last week... settling in for the wait as best as we can.
Specs: Dual swing outs. Passenger side with spare tire, hi-jack mount, and camera relocate. Driver side with ladder and swing away rotopax mount.
Color: Powder coated silver to match our front slim line.
Special requests: 7 Pin socket relocation to bumper face to move it out of harms way. We've almost crushed the Turtleback's cable a few times... the metal rear bumper will be much less forgiving against rocks.
Also, I'd like to mount a quad band antenna for my future FT-8900 mobile unit somewhere on the assembly but haven't got to talk to Kevin in detail yet on these special items.
Looking forward to seeing everyone's bumper installs!
So...
Do you know what helps the wait.... Photos. Lots of
Photos. Maybe some fabrication photos. Some more installed bumpers....
A beautiful woman in a bikini hanging off the side ladder. You know. Pictures.
Just saying... Throw us a bone... Please. :hail:
Status
