TRDZEB
I would LOVE that if they did.Has SSO developed the angled rear camera mount to get the view back to / close to oem?
Sent from my SM-N910V using Tapatalk
I emailed the gang at SSO right now to see if its on the agenda, if not already in the works. I know there was some rumbling a month or so ago. I should hear back from gwen or kevin monday. Will update thread on what i hear.
Probably should have gone with the HD springs for this bumper setup.
One note... I didn't get the extra swing arm with the jerry cans......
Shoot, now I'm nervous... Well... the good thing is the rear springs are a cinch to switch out.
This is with the 2" toytec lift. As you can see, slight sag, the HD sprigs would be preferred.
Now they just need to restart production on the rear bumper. I wish I pulled the trigger back in November when I ordered my front SSO.
Went thru the same scenario with your lift and rear bumper a while back. The OME 2889 or 2898 work well, I preferred the 898 since stiffer and handled nose dive better.
Since we run pretty heavy with a trailer to boot I went with the 2899's and love them so far. Keeps a decent rake unloaded but levels out when outfitted. I have the Icon stage 2 kit so I can adjust the front as needed.
The 2898's will probably work best for the majority of folks.
I agree. It's more function vs fashion. I have the HD springs and my front sits slightly lower but under full load it sits more even.That extra swing arm has a little weight to it, but of course the bulk of the weight will be the actual bumper and your spare tire.
My buddy that's been running the bumper with both swing arms, is running the Icon 3" Overland Springs. His rear sits about as high as my Toytec 2" springs in the rear (my bumper isn't on yet).
Me personally, I'm swapping out my springs to the HD springs.
Toytec HD springs, Icon Overland springs, and others alike are meant to handle the extra weight of these bumpers and maintain your lift height with no sag. They level back out with the weight.
Now, I have also seen some guys run this bumper for a while with just regular lift springs. You can tell the difference, but its doesn't look ridiculous.
Also, keep in mind that when you load up stuff in the back it will sag a bit more with springs not made to accommodate for the extra weight.
There's not really a wrong or right here, I guess it depends on your preference, and what you do in your rig.
I logged onto the Southern Style Offroad website today and it says that the rear bumper is discontinued. I called to verify as well. :Cry:
Meaning they will not make it anymore???
