Even Steven said:Falls,
The small spacer you're considering installing (1/2") will not affect ride quality at all. You'll never even notice it's there! Trust me!
808BMW said:Most 3" front spacer kits are 2 pieces.
The lower bottom spacer is called a pre-load spacer. This goes between the spring and top plate.
The top spacer goes above your top plate and pushes the entire strut assembly down away from the shock tower.
I've heard that pre-load spacers affect ride more than topout spacers, while a topout spacer will limit wheel travel more.
There is no different setup in the rear as far as I know.
airbur said:Hi Falls....you have been talking about this lift for quite some time now...when are you going to bite the bullet and go for it??![]()
