spark plug gap
Armandi
everything i read says teh 98 runner needs a plug with a 44mm gap, but the toyota service manual sayd 43mm. if i buy a set of plugs that say 44mm do i need to adjust the gap?
Your engine can't tell the difference between 43 and 44mm. Take either one. Just check that they are all about the same.
44mm or 0.044"
44mm is about 1-3/4 inches. Do you mean 44 thousandths of an inch? If you're talking about thousandths of an inch, there's no practical difference between 43 and 44 in terms of a plug gap. Typical wear and unit-to-unit variation is likely to be in that range anyway.
