Spark plug question for 2000 2.7L
DriVen
Ive searched and searched to no avail. I have learned that the 3rd gens run best will dual ground NGK plugs but thats been for the v6. Is this also true for the 4 cyl?
I replaced the plugs a couple thousand miles ago with single ground and im only getting about 15mpg at best and starting to get a rough idle. Any ideas?
I looked around, too. The single electrode spark plug is sufficient, and I am not sure you will gain anything from extra electrodes.
I just run NGK plugs and wires. You sure the rough idle is due to spark plugs? Try out a different set if you think so.
Well I have the coil packs so all i did was replace the cheap Autolites with NGK, cleaned the Throttle body and the MAF. Didn't notice much of a difference. Gonna run some injector cleaner next and try things one at a time i guess...
For sure. I'd suggest a Seafoam treatment and a good oil and filter.
I made a little guide here to show how to seafoam a 3RZ 2.7 liter effectively.
There was a hole debacle on the 5VZ engines with "how to correctly seafoam."
http://www.toyota-4runner.org/3rd-gen-t4rs/83156-youve-been-doing-wrong-seafoam-injection-port.html
But I have gone ahead and posted how I do Seafoam treatments on my motor.
3RZ 2.7l OWNERS:
DO HALF OF THE TREATMENT USING THE BRAKE BOOSTER LINE ON THE INTAKE MANIFOLD. Then, if you look on the other side of the intake manifold, you'll see another vacuum line on the opposite side. Use this to finish off the last two cylinders.
Works well and thoroughly for me, and I don't give a damn if you say otherwise.
3RZSEAFOAMDIAGRAM.jpg~original
I wanna try the sea foam but my dad and his mechanic buddy have been telling me otherwise thinking its too harsh on the whole system and making me think twice. I do appreciate you posting the write up for it though. Youre awesome, and so is your rig
Thanks buddy.
I understand your concern about the harshness of the additive. Seafoam's website does say otherwise, though. Seafoam is not a harsh chemical and can be used frequently. It is safe for plugs, seals, oil, catalytic converter, sensors, what have you.
BG44k is something you'd consider harsh. It's recommended for very spaced out intervals, like once every 15k miles at the earliest.
Check out this FAQ for more Seafoam related questions:
Sea Foam | Gasoline Engine FAQ's
Sea Foam® is not a chemical engine flush and therefore, it will not damage internal engine components or plug the oil pick up screen. Sea Foam® is a pure petroleum blend with no chemical additives and is safe for long term cleaning or short term pre-service cleaning.
Sea Foam® is a blend of highly refined additive oils and is compatible with all motor oils including synthetics. It is safe for all internal engine components and will not affect any seals, gaskets or o-rings. Sea Foam® cleans oil deposits and varnish in your crankcase by safely/slowly re liquefying the old oil residue so contaminants may flow and be filtered.
For more than 65 years, Sea Foam® has been proven to be safe for use in all engines, both diesel and gasoline, and won’t harm gaskets, seals or other internal components of the engine, fuel system or oil system. Sea Foam® is a pure petroleum blend with no chemical additives. Sea Foam® has been endorsed by numerous engine manufacturers, and is recommended by thousands of professional mechanics and service technicians throughout the U.S. and Canada.
