skkiii_whhaattt
anyone know if theres a write up on how to install new speakers and tweeters in place of the stock ones w/o an amplifier?
tarheeltp17 said:Heres my 2 cents... by working at a shop I've learned a few things...
If you have problems working on a toyota, then you probably don't need to.
Seriously, toyotas are some of the easiest vehicles to work on, esp the 3rd gen 4runners. You don't need an amp ever. While it will make the speakers sound better, you don't have to have one.
Just take a look at your door panel and figure out how to take it off... I swear its nothing more than a few screws and it pops off. If you really need pictures I suppose I can do that.
It's obvious about taking the screws out, I've removed every screw on that plastic piece with the speaker in it and it seems like it is glued in there or something, or maybe its just me being scared of snapping something in half. Either one is a possibility.tarheeltp17 said:take the screws out possibly?
tarheeltp17 said:you are trying to do the rear speakers correct?
I work at a shop here in NC, but I can't remember exactly how to do it. I just got my 4runner about 3 weeks ago so I haven't replaced the speakers just yet.
Normally if there is something tricky about a car, I'll remember how its done but if its something simple its just one of those things you just do. It probably is just sort of glued into the plastic piece. I'm off thursday so I may just pull off my rear panel and see if its anything tricky. But honestly, seeing as how its toyota, it's probably not.
