speed limit on using 4 wd (on-road)
If you are asking about the V6 multimode in 4WD, you are not limited by speed. You can go as fast in 4WD as you can in 2WD...
BigGame said:
If you've got the full time 4WD V8, I think its around 116mph...:D
LOL
Are you talking with it in 4x4 mode (V6) or (full time 4x4) in the V8 or are you talking with the center diff. locked ?? Personally I don't think there is a limit except you own on either mode. The manual does not say anything about limit's except for common sense.
depends on your locale - regardless of 4wd, the highways here are usually capped at 65mph or 55 mph :D
Jacobzky said:
is there a speed limit when running on 4WD on-road (side streets & fwy)?
I believe this is correct for any 4th Gen... unless you have disabled the speed limiter in the ECU.
Falls said:
LOL
I don't think you're gonna want to be cruising around at highway speeds with the center dif locked, right? :confused:
The speed limit depends on how big your b____s are!
Joking!
I chicken out above 100 mph... the worst thing is the rpms were not even at 3500 so it seemed the 4R want it to go far higher...
I said Heck No!!
Yeahhh yeah I know.... b___s not that big.... but brain is!
05SV8
Is there a liminit on how fast you can be going when you turn it into 4x4? It seems to me that you have to be under 55mph, I can be going 57 and turn it in and the lights just blink. But the second I drop below 55 they go sloid.
Coop
Coop
Manual says 62mph going straight and not turning from H2 to H4. Doesn't mention any speed limitations from H4 to H2.
