Spidertrax 1.25" spacers on 2010-2013 TE stock wheels with lift?
Matteblack
Member
Is anyone running these with stock TE wheels and a lift? I have a 3" lift with BMC and 285/75/17 (34") tires. Currently no rubbing with the tires but wondering if I add spacers will that change?
According to the wheel offset calculator I just tested with, my current setup is 0.59" wider than your existing setup on the stock TE wheels. I currently have zero rubbing. Your proposed new setup, would be roughly 5/8" wider than my current setup and would be closer to rubbing gently. It wouldn't be major though, and likely wouldn't take much trimming.
Your proposed setup would be less aggressive than if you switched to a -38mm offset wheel, and I see plenty of guys running those on 4Runners with stock (but trimmed) fenders.
