dbg
Spinning noise when clutch is pressed in idle gear
My 2000 4runner SR5 4WD is at ~106k now. Recently I kept making spinning noise whenever I pressed down clutch or between gear shifts. I know this noise is embarrassing when you drive stick. I barely can avoid making this noise in the past two weeks or so.
Is this a wear-out problem on the clutch? I read online and saw that a worn throw-out bearing could cause such a noise. What type of 'bad' driving habit could cause it? Or it is simply an aging issue?
