squeak when clutch is out
jmcgahran
I had my clutch replaced a 1000 miles ago. Now when the clutch is out there is a squeaking noise. If you put any pressure on the clutch it stops. Also when you idle it is a noticeable squeak, squeak, squeak, but if you rev it above 1100 rpm it goes away. I don't know if this is a coincidence but I just replaced the upstream o2 sensor. Before I replaced this the squeak got louder as you revved it higher.
It was just replaced with the clutch by the dealer.
Exactly, They are hit and miss and every once in a while you get a noisy one out of the box. I have a good feeling its the culprit. My best advice: deal with the squeak, it doesnt effect the performance of it. My last one I put in was a little noisy at first
