Squeaking question!
Theo85
So I noticed that while driving around a bend in the road at any speed over 60 km/h, or turning sharply while there is weight transferred to the drivers side of the vehicle, i get this squeaking sound coming from the front driver wheel well or tire area.
I feel like it may be the driver side bearing going bad, but when i drive straight or turn left there is no noise and drives smooth otherwise. Any ideas?
I'm guessing a front wheel bearing is on its way out. A possible reason you hear squeaking on certain turns is the bad bearing is basically letting the hub/rotor/wheel to move around slightly which is making the rotor contact the pads in the caliper.
utkrstam
