squeaking sounds
sheri
any suggestions on the squeaking sound comes from front either its shocks/ coils/springs/rubber,have tried wd40 it works for a while then sound starts coming again. thanks.
sway bar and links
just a guess -but perhaps check your front sway bar and end links
Have an alignment done and see what the tech spots-possibly you have an inner or outer tie rod end working loose.
Re: sway bar and links
thanx but i sprayed wd40 on the shocks and coils and the sound stopped, but will work on your suggestion thanx again.
