Squeal When in Reverse
4Rnnr99
Started noticing a bad squeal but only when in reverse. Squeal speeds up as car speeds up (in reverse).
I found posts elsewhere stating this is caused by a bad u-joint. When I took it to the dealer, they said it was the drive shaft, but no need to fix right away and it is very expensive to fix.
Anyone else have this problem and should I get a second mechanic opinion?
