What does that have to do with the brakes???Did you check the rear to make sure you don't have leaking axle seals?
Ummmm.....nothing
I'm guessing he must have been thinking that when the axle seal leaks, the gear oil from the diff gets on the brakes and ruins them. That wouldn't affect the pedal going to the floor though so that's not it.
Are you sure you didn't allow the reservoir to go dry while bleeding? If that happens, you need to bleed the MC and then re-bleed the rest of the brake system. There are two chambers in the reservoir so this mistake is easy to make. Ask me how I know. Bleeding the MC is easy, instructions in the FSM.
I had a shitty brake pedal. And a good bleed from someone who knows fixed it.
I am having this problem..i think the reservoir ran dry while bleeding because my buddy didnt know i had the line cracked open (miscommunication)
SOOO, now i have bled the shit out of my breaks. no air in lines. still squishy pedal.
1.) I dont have a FSM, so how do I bleed the master? Do i just undo the 2 lines from the side of it, attach tubes, and feed tubes into the resevoir and pump the shit out of it?
2.)I have ABS, could air be in there too?
3.) does a 98 4runner have a brake booster?, do i need to bleed brakes with the key on?
sorry, im new to 4runners. Basically i just did the axle seals and reinstalled everything, brakes were rubbing a bit so i left the adjuster turned all the way in. I spose its now possible that the rear pads are not engaging at all. would this cause a squishy pedal?
any help here greatly appreciated.
So, I fixed my brakes today. Turns out I got air in the ABS system, heres what I did to correct; Went to a dirt road (to be nicer on my tires then pavement) made the ABS activate several times to push the air into the lines. Went back home bled them the old fashion way. And repeated the process 1 more time, now they are as good as new!
Thanks for your answers man, yeah i searched for hours, actually did read your thread earlier, just thought there was another way to bleed it. I tried what you said earlier today, but only once. Didnt help, i will do it 5 times tomorrow.
No way to attach hoses to catch the 5 pumps of fluid that are going to come out i assume.
Im really starting to wonder if its my un-adjusted rear brakes that might be causing this problem...i mean if the rear pads are not engaging at all, maybe thats where the squishy-ness is coming from?
Anyways. i will report back on this thread tomorrow, thanks again!
Nothing comes out, strangely enough. You just feel vacuum against your fingers when the pedal gets released. Once is definitely not enough.
If the rear cylinders have a lot of free play, that for sure will squishify your feel. If the adjuster is at minimum, I hope your pistons all stayed in their cylinders. If one pops out, you'll have a real mess and no amount of bleeding will get things working.
