Brandonium
Member
The AC in my '77 International Harvester works.. but I'll be damned if that can't be approved upon. Being old school shouldn't deny that some advancements are good even if what is being replaced 'still works'.
Sometimes old school is also known as stubborn. But hey, that Scout has top notch tech for....1977.
KDSS isn't only useful for corning at 65mph but I could see where this could be construed from all the posts that state this as being the reason for the existence of KDSS. :baby:
I have a '13 SR5 4X4 - stock except for E rated TOYO MTs. If I had it to do over again I would buy the exact same vehicle in a minute.
The lever vs the knob: I spent a week in Utah driving my cousins' '10 SR5 which has the lever - I could find absolutely no advantage to the lever over the knob. In fact , my previous Land Rovers had the lever shifters no advantage.
Crawl Control and MTS: Fluff - No need for it at all - If you pick the right gear in low range you're good to go.
A Rear Locker: For years I've been leading every kind of 4X4 you can name out in the boonies (Toyotas, Jeeps, Chevies, Dodges, Fords, Land Rovers) some with rear lockers and some without. With A-TRAC (Land Rover has been calling it 4ETC for almost twenty years) you really can go anywhere that the locker will go without snapping axles.
KDSS: I really don't care if you can go around a corner at 65 mph on pavement. I bought it for going around corners at 5mph on dirt, rocks and sand.
A Hood scoop: BFD - My old Subaru had a hood scoop bless it's little heart - So do Camaros, Mustangs, GTOs, AMXs, Road Runners, etc - - at least some of those are functional.
THIS IS NOT A HATE REPLY - It's just that I'm of the old school, "If it works then leave it alone".
BTW: I don't know why Toyota even has a switch on the A-Trac in 4LOW; I keep it on all the time.
Now if Toyota in their wisdom would only put some real steel bumpers on both ends instead of all the plastic - - - -:der:
