Started install today
Lizardking
I got sick of waiting for the Eclipse AVN5495 to do my install so I started without it today..
1. Dynamatted rear with Extreme dynamat and acoustic spray. Did the entire floor and inner fenders all on the inside of the vehicle. I sprayed all the panels and interior trim with acoustic spray (inside on panels). Doing rear hatch tomorrow, already sprayed the plastic panel.
2. Installed my Eclipse camara. Put his under the plastic trim on the outside of the hatch. The Eclipse camara comes with a cable split in two sections.. Somehow when I was running the wire I broke both clips off. So I ended up soldering the cable together..HOPE THIS WORKS!!!
3. Built my amp rack today.. Used 3/4" MDF.. Amp rack has two sections, one for each amp.
Tomorrow:
Finish rear hatch and run power cable from Battery!
SHOW SOME PICTURES...
DO YOU GET DONE THE JOB ON YOUR 4RUNNER ...
I WILL BUY THE SAME HEAD UNIT AVN 5495...LET NOW THE DETAILS INTALLATION...
THANK'S
