Hi everyone, I read pretty regularly but rarely post.
Today I ran into an issue I am hoping maybe someone knows an answer or suggestion to.
I work near my house and had to go home at lunchtime. I went out to my 4runner (99 w/103,000 miles) and turned the key and click. Just one solid Click. Not multiple clicks like when your battery is low and doesn't have enough to cranke the engine. SO I released the key from the start position and hit it again... Vroom. Turned over and started and seemed fine. Drove home and ate my lunch etc. Went out to the runner to go back to work. Hit the key. and one click. So I let off and hit it again. but this time no go. I proceeded to try it about 8 to 10 more times. Nothing. The lights, gauges, clock etc were all on and worked fine. I also did not suspect my battery as it is only 3 months old. I had just replaced the original with this one. In any case I called and got a ride to work and finished the day. came home and tried it again a few times. Just click. one single click when you turn the key. Odd I though. anyway I took the battery and charged it JUST in case. it wasn't low but I let it charge anyway. Hooked it all back up. Same deal. Then in an effort to make something happened I hit the start position about 4 or 5 times really fast. Like run/start run/start position rapidly. at about the 4th time it wanted to turn the engine over. like it came free or something. I then did it again and held it and it started fine. took it for a ride and came home and shut it off. I then tried to start it again and shut the engine on and off completely 4 more times and each time it started just fine.
I have not idea what that way but it worries me a bit. some people told me to check my starting selinoid. Don't know where that is or if a 4runner even has one. and one guy said maybe a bad spot on the start itself.
If anyone out there has any idea please let me know! Thanks
