Steering noise after body lift
Lignum
I just installed my 1" BL last night. Now when I turn the steering wheel about 30% to the right it makes a growling noise, but just at a certain spot in the range of motion. Any one have any ideas? Is my power steering pump gonna die?:shrug:
Did you loosen the steering shaft clamp before you installed the BL and tighten it back up in the new position?
I loosened the rag joint bolts. After I lifted it I realized I should have loosened the splined shaft clamp instead, which i did afterwords in order to install the aluminum spacer provided with the kit. It was pulling a little becuase I left the rag joint bolts in the holes just loosened all the way. Could this have caused damage?
It the TIRE rubbing on the BUMPER!!! I think it is because the 2 outermost mounts bolt to the BODY and the other bolt to the frame. Therefore, the bumper is at a downward angle and pushes the back of the bumper that acts as part of the wheelwell, into the tire.
THat is what I was thinking. If you didn't lift the bumper, it is angled slightly toward the tires, and therefore will rub on them when your turn, ...., probably right around 30 deg.
Ya right about here......
DPP_0006.jpg~original
