Steering rack bushings 2010-2013
WarnerD9
So my steering rack bushings are going bad and no replacements are available. Only way to replace them at this point is to replace the whole rack ($975), Toyota states on the parts diagram that they are too difficult to replace. No reman options. Has anyone else dealt with this and found a solution? If so, please share. Thanks!
That's just the price of the rack, right? It's something like a 16 hour job to replace the full rack since on the 5th gens the engine has to be lifted a bit.
Hi Intruder:
Notice that you have a 2011 TE, mostly stock that has never been wheeled, so what's the story about your steering rack being replaced? Not being smartass; I have a 2010 TE with almost 71,000 miles now that has been thru some light offroading and hope that this is not something I have to worry about replacing.
Thanks, toyslug
Hi Intruder:
Notice that you have a 2011 TE, mostly stock that has never been wheeled, so what's the story about your steering rack being replaced? Not being smartass; I have a 2010 TE with almost 71,000 miles now that has been thru some moderate offroading and hope that this is something I have to worry about replacing.
Thanks, toyslug
Was your moderate offroading like this? http://www.toyota-4runner.org/5th-gen-t4rs/143951-intruders-build-off-road-pics-thread-3.html (go to last pic in post #39)
Yeah sorry, I'm a complete smartass and my sig is a straight up lie. My truck is pretty heavily modified but I still get people asking me if I actually take it off road so that's where the sig comes from. Check out the link that [MENTION=66316]1engineer[/MENTION] posted and you'll see I take it off road pretty often.
Was the whole rack going out or just the bushings?
Whole rack went last year. You could feel from lock to lock that it'd get hard to turn the wheel, then ok, then hard to turn again. Just a couple months ago I had the steering shaft replaced as well because it had flat spots in it. The steering shaft was a lot less expensive at around $700 parts+labour.
LOL Joke's on me! Should have figured it out if I had looked closely at your avatar, Intruder.
Hey 1Engineer, Especially after I saw your response I had to make another correction edit to my "offroading".
Also wanted to make the point that I destroyed my tire not during light offroading that day but it happened soon AFTER I returned back to the PAVED highway at the end of the day!
Curious how this works out...probably not far behind you guys. Just did my first wheel bearing and both tie rod ends.
Also if you're dropping over a grand anyways, call up Safari Ltd. in Grand Junction and see if they can make a stronger than OEM rack...they do for the Tacos...
That's how it always happens, bajaing through rough terrain, bruising the tires then heating them up at high speeds. Pressure leaks just slowly enough to get your attention then it fails and it's all over. Sorry to hear that.
Do I really need to lift the engine? Oh man I hope not. I need to replace my bushings but I think i'm just going to do the whole rack. Please tell me this is not true haha.
