Step 1 done 3" lift now i need tires and rims mabye
l3igl3ang
Ok just put on the 3" lift top spacer lift took about 4 hours surprisingly it was way easier then i thought. The part that gave us so much trouble was the passanger side shock them things are a pita to get off when there origianls. I had the same problem with i did my 2wd. So any way it looks great its a kit off ebay for 180 shipped but it dose the job now i need some tires for this any ideas?
i found these one ebay for 800 a set but i kinda like the wider tire look not the narrow look which i dont know if these are narrow look?
4 NEW LT 285 75 16 Maxxis Bighorn Mud Tires 75R16 R16 Load Range D 8 Ply 2857516 | eBay
i also found these and i can get them local cause its in my town but i dont know if they would work with a 3"
**** Cepek Crusher Tire - 305/70 R16 - 33x12.50 R16 | eBay
and now heres the pics of the lift installed
The no name spacer
lift with new shocks
well im thinking of going ahead and doing a 2" body lift as well and run some 35" tires I just dont know how bad 35's bog down the 3.4 v6 w/o 5.29 gears. I know i run 33's on my 4cly 22re pu 4.10 gears and i was able to poop and get all around town but it would'nt do over 70 on the hwy. I plan to just use this 4runner on road most times i got a 87 that i can use for a off road toy! so i would'nt be flexing much with it so i shouldnt have to worry about rubbing issues. I read others haveing 3" SL and 2" B and running 35's
Looks good!! I still need bigger tires for mine too! Im running 265/75/16's now, basically a 32" tire. Not near big enough. I will be getting some 285/75/16's soon. Looking good!
charlesz
