285 R16 Ridge Grapplers with Toytec Ultimate 3" lift???
Lunarphase
Member
I'm looking to go the the next size up on tires. I have a Toytec Ultimate 3" lift and running 265 R16's. I also have the 1.25 spider spacers.
Looks like there is space to go to the next size up so I'm looking at the Ridge Grapplers in 285 R16's. Is anyone on here running this setup?
Any opinions appreciated,
Yes I did a search but couldn't find a definitive answer, sorry
What wheel you are using is also going to affect fitment. By the way, when you give or look up tires you need all 3 numbers. Tread width/aspect ratioRrim size. So in your case I’m guessing you are going from 265/75R16 to 285/75R16. If that’s the case then your tire is an inch wider and 2 inches taller. Which means an extra 1/2” in tread width on each side and an extra inch taller/further from center of wheel.
"So in your case I’m guessing you are going from 265/75R16 to 285/75R16" Yes
This is the tire I'm looking at (Nitto Ridge Grappler All- Terrain Radial Tire-LT285/75R16)
Original 99 wheels 16's
eIT1zYK
Thanks for the info. I'll get under and have a better look
