Stereo Harness Question
TXRick
I pulled the after market stereo out today and am going to replace it with my old JVC SatNav out of my caddy. I was looking at harness' online but am not sure exactly which one to get. The previous owner put a head unit in and kept the stock cd player which didnt work.
cv003_zps1311ac6a.jpg~original
cv004_zps7b88788f.jpg~original
cv005_zpsf20ec32f.jpg~original
cv006_zps9ed13919.jpg~original
These are the harness' im looking at.
different
http://www.carparts.com/details/Toy...tbesbha81101&gclid=CLjx_oXAkbgCFVRk7Aod6CEA9Q
different
TOYOTA 4RUNNER RADIO DASH INSTALL MOUNTING KIT SINGLE DIN POCKET & HARNESS on eBay!
From cruthfield with in dash cd player
different but close
Metra 70-1761 Receiver Wiring Harness Connect a new car stereo to the factory wiring in select 1987-up Toyota, Lexus, Scion, Subaru, and Geo vehicles at Crutchfield.com
See my confusion?
I wired mine without a wiring harness, I hated the previous owners aftermarket head unit. He had cut the Toyota stock wiring harness so i had to hard wire the new head unit I picked up as well. After following his wiring I quickly found out he was an idiot. If you don't want to use the wiring harness at all here is the color codes for the stock wires. Just look up the color code for your head units wiring harness and match up the correct colors and crimp them together. It will take a little longer but will save money and wait time on the harness being shipped
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Violet
Car Stereo Dimmer Wire: Black/White
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Thank you so much! Great info. The person who installed this aftermarket radio was also an idiot. I hate that we have to put up with someone elses stupidity...it only confuses me :)
Yeah, it wasnt there when i pulled the old radio out. It looks like 4th of July snuck up on me so I am going to get back on this Monday. Woot! Independence Day!!
I just bought one from Best Buy and it really was plug (solder) and play. I think it was $15-20 and they had it in stock...
I'd just call crutchfield. They have the correct harness and will let ya know which one ya need -
I agree with afg10000, call crutchfield. Their customer service is awesome.
I figured it out. It looks like the person who installed the aftermarket radio did not use a harness at all. Crutchfield and Best Buy all had the same harness and they insisted I use the one they specify.....if I had the original equipment then I am sure the harness would have worked but I do not so time to crimp and cut!
i am confused on the diagram. i am working with a 99 4runner and my question is on the Car Radio Illumination Wire: Violet and the Left Front Speaker Negative Wire (-): Violet are they the same wire? because i only have one violet.
Revived from the dead.
Scrhew, did your truck come with the stock amp? I'm about to wire in an aftermarket deck and this was the best wiring list i could find. I'm no google or search button noob either.
I'm sure his did. If you are replacing from stock the harness you get at bestbuy/crutchfield should be a plug and play situation, but in my situation ALL the wires were cut so I used his diagram but if I remember correctly the wires matched up color for color anyways...
I think i just answered my own question. The amp is removed when you install an aftermarket deck, so you're dealing with the wiring straight from the harness, not the wires from the amp. Amirite?
They are not the same wire. Assume yours is the speaker wire. The other violet wire is only in the harness between the stock amp and the stock HU. If both stock amp and HU are gone, then so is the other violet wire--no biggie.
If you want to confirm, take a D cell battery and touch between the violet and the pink wires. You should hear a click from the driver's door speaker.
BTW, one error on the list is the antenna trigger is the black/white wire--4Runner had no dimmer function on the radio. My list is the factory '99 4Runner EWD manual.
Yeah. Ideally you can use the harness plug and an aftermarket conversion harness with your new HU pigtail. But if dumbass PO cut out the plug, you have to crimp and cut to the body harness.
But if dumbass PO cut out the plug...
uuhhhh....yea, what kind of idiot would do that...hahaha
I always cut mine to be honest. Who plans on going back to a stock system? I do a clean wiring job too, so i really don't see the point in paying and waiting for a harness adapter that only works with one brand to come.
Having said that, I've definitely bought cars where i wished the PO used a harness adapter ...
I'd rather build my harness adapter on my kitchen table than lying under the dash of my truck. Goes at least twice as fast and results are better. (I solder/heat shrink as opposed to crimp.) And the old adapter works with any new HU, you unplug the old one, cut off the old HU plug, and splice on the new pigtail from the new HU. This is true even if you have a full adapter (Pioneer to Toyota)--you just cut off the Pioneer side and use the Toyota side to marry to your new Alpine HU pigtail, for example.
After 4 or 5 HU's, you might not have much truckside wire left if you keep cutting. Maybe not a concern if you are buying with 200k, but I ripped out the stock system in my 4Runner the day it got home new from the dealer in 1999. I was not going to hatchet the stock harness. And I'm probably on my fourth HU by now, and ready for number five. There was no waiting--I bought the Alpine HU and harness before the truck was ready at the dealer.
ahhh i see what you're saying now. I always figured you needed a new adapter harness for each brand or when they update their plug. I'll be doing this next time, thanks!
IvkpFzi
Sorry to revive an old thread, but can you tell me what the dark green wire (behind the blue/yellow wire), and the black wire connect to?
