Stereo Install -> no dash or instruments lights. Blown fuse?
seeking3rdgen
I reinstalled my aftermarket HU today (swapped in the JBL, then switched back to aftermarket), and now I don't have dash lights or instrument lights. On the dash, the needles and the odometer light up, but the gauges don't. On the climate control, the little LED arrows light up, but nothing else. Also, my automatic power window (or at least the driver's window) goes up and down but doesn't "auto." If this is a blown fuse, any idea which one?
I had a 10amp fuse go that was in the dash compartment did something similar and the brake lights out with it. Other than a fuse you may have mixed up a wire. Or the dimmer switch could be a option.
Did you reconnect the dimmer switch? and did the dimmer switch get moved all the to the down position
And as for the window you need to reprogram it with a certain procedure which I cant remember at the moment.
I think its lower the window then raise it and after its closed continue to hold the switch up for a few seconds. then your auto up and down should work
utkrstam
