Stiffer front and rear springs for ‘19 Pro
tls3601
So I am anticipating a Prinsu full-size rack and an Alu Cab RTT in the future. As that tent weighs like 190 lbs I am look into stiffer front and rear springs to avoid sag and avoid hindering on pavement performance. Anyone know of anyone that sells stiffer springs for the Pro that will NO change ride height? Thanks.
I believe the fronts are 12.6” 600lb. You can probably get the 650lb 13” icons. Marginal 0.8”ish lift. Not sure if King makes a 600lb 13”?
Rear - I think Dobinsons has something. I’d probably go with the load leveling kit from Eibach, though.
Philthyphilthy
