02_SE_Runner_DAD
For guys/gals that have done a stock 4wd conversion. How long will it take to do a stock 4wd conversion if you have two 4 runners side by side and taking parts from a 4wd and swapping them to a non 4wd?
TIA
TIA
You have to move the transmission crossmember location for the 4wd transmission mount to be able to bolt up to the frame. You'll also need to cut out, transfer, and weld the section of body around the transmission and transfer case shifters. The body opening for the transmission and transfer case shifter are different.Thank you for that great info! What is the welder for? Does everything just bolts on to the 2wd? Really appreciate this info and thank you. I might have some more questions if you don't mind.
Make sure you change the rear upper control arms when you do the transmission (2WD and 4WD upper arms are different).
-Charlie
4WD upper arms are longer.Hey phattyduck, just looking for clarification as to what is diff with the rear upper control arms?
As was already said:Thank you for that great info! What is the welder for? Does everything just bolts on to the 2wd? Really appreciate this info and thank you. I might have some more questions if you don't mind.
The 4WD pinion points up at the transfer case output (due to double cardan CV joint) and the 2WD pinion is level due to two single u-joints in the driveshaft.
-Charlie
$300 for the rolled 4Runner with no motor, about $500 in maintenance parts (seals, fluids, broken part replacements, etc.) and about $500 in beer.phatty.. how much the 4wd conversion cost you?
