Stock FJ bilstein shocks & springs
MaliciousClout
Does anyone know if I add this to my 05 Sport what kind of lift I will achieve? If any at all? I have XREAS, and plan to scrap it.
Will I also need to add DS 2.5/1.5 to get her leveled?
Or will adding the Stock FJ bilstein shocks & springs to the trick?
Thanks in advance guys, really need some insight and I appreciate your help.
Check HERE for FJ spring lift feedback. Also, it depends on what "doing the trick" is to you? Do you want it leveled, mild lift, moderate lift, etc. Also do you have V6 or V8 as this will also result in different lifted amounts (again, see the feedback thread).
Since you mentioned leveled in your post, you're probably going to have more lift than you want if you add the DS 2.5/1.5 spacer lift to the mix. It varies but you would probably see somewhere around 3.25"+ in the front and 2" for the rear.
I definitely want it to be leveled and noticeably lifted. It's a V6.
Ok, so the springs will lift a little more due to the lighter engine. Honestly, you just need to browse through the "Lift and Tire Central" thread to figure out exactly what amount of lift you want. Then, figure out how you want to get there based on the amount of money your willing to spend (spacers, springs, coilovers, etc).
I just installed the Bilstein 5100/OME 884/SAW 2.0 coils on mine and I love it. There are plenty of options. Just find whichever works best for you.:thumb3:
