stop leaks
brianbu
I replaced my water pump and timing belt, for some unknown reason the pump is leaking at the gasket, is there a good stop leak to temp. stop the leak until I have the time to take it apart again:crybaby:
Stop leak will just make a huge mess. Get the gasket on order and do it ASAP. in the meantime I would take the bus or bum a ride from friends. A leaking water pump is not something I would just be running around town with, you are at risk of a catastrophic cooling system failure.
tuṣṭāva
