Strange noise heard while pressing on gas
Thanks Alp.
I will def check this out when I get home later today. I am somewhat thinking my issue is something else, I say this because my "MMMmmmm" sound is coming from the drivers side front, not the passengers side.
RMD139 might want to check this out because he described his noise coming from the passenger side.
Ill check this out later...If its not the cat shield I will know after I get my rig to the mechanic tomorrow.
Just a couple weeks ago I started hearing the sound you're describing, kkinda like a tapping sound coming from passenger seat. Sound is very faint only if I turn down radio i can hear the dreadful tapping..... could it be a loose bolt?? idk, got 130k miles:boxer:
I just got a call from the mechanic. He could not find anything wrong with the vehicle and nothing was making any noise or loose while he had it on the lift. He thinks its the road noise from the tires...Im not so sure because it's never done this before.
I am having him change the diff/ transfer case fluids and grease all the fittings because this is one thing I forgot/neglected to do. I know RMD138 changed his front diff thinking that was his issue and the noise did not go away.
Another thing I forgot to check was the spare tire to see if it is loose.
When I get it back Ill see if this helps ad will let you all know.
Thanks,
Steve
I check the cat shield, its not loose or making any noise when I hit it. Also, checked my spare tire too, thats snug.
Still making noise...not sure where to go from here. I guess Ill deal with it until it really starts making noise all the time. Im sure when I head back to NH from SLC it'll be roaring, just hope I make it back. HA!
Believe it or not but it looks like I fixed it.
I spent some time today under the truck trying to find the source of that annoying/alarming noise and I finally found that the heat shield on top of the muffler (not the cat converter heat shield) had one loose nut . Tightened that nut and took my truck for a long test drive. The noise has gone!
I will report the final verdict tomorrow when I get home from commuting to work.
No more rattling at all. I am pretty much sure now that the source of the rattle was the loose corner of the muffler heat shield.
I hope my finding will help to somebody else to fix the similar problem.
Thanks.
Just read thru this thread! I'm hearing the same type of sound, it's like a rattling noise and can only be heard at low speeds during acceleration. Big thanks for everyone keeping this thread updated with possible solutions!
Got my magnaflow installed yesterday and i had the guy tac weld a loose corner of my cat heat shield. The nut and bolt that was holding that corner seemed to have rusted off. The muffler shop guy said that'll take care of that rattling noise under acceleration but I'm still hearing it! How difficult is it to grease the drivetrain? (shafts, joints, etc)
Hmm. Gas tank skid plate? There are rocks in mine, I wont be able to get them out without taking the darn thing off... Did you check there too?
seltzernator
