Stuck CAPS's snail build!
Stuck CAPS
I decided it's finally time for me to make a build thread, as I continue to mod my Runner, and I have no one else to share the glory with! I called this the snail build, as it's been a relatively slow build, and it will continue to be.
2004 4Runner SR5 v6 4x2
Current mods (as of 9/7/2013):
Interior:
-OEM All-weather floor mats
-OEM Limited Cargo Cover
-OEM Cargo Area Floor Mat
-LED Map/Dome/Door lights
-Stickerbombed Dash (to cover the cracks lmao)
Exterior:
-Yellow, Independant Fog Lights
-Bright-ass eBay LED Reverse Lights
-OEM Running Boards Removed
-Plasti-Dipped Grille, Lower valence trim, Tailgate Trim, and rear Bumper.
-A Couple Stickers ;)
-Rola Vortex (waiting on drop brackets, then I forgot about them)
Suspension/Wheels/Tires:
-265/70/17 Goodyear Wrangler Adventure A/T (one is a Silent Armor, my old spare, long story).
-'07 FJ Stock Suspension
-DayStar Comfort Ride 1" Leveling Kit
Engine/Intake/Exhaust:
-AFE Cold Air Intake
-NGK Iridium Spark Plugs
-Meineke "Turbo" Muffler
-TRD Exhaust Tip sitting in basement still, got a free tailpipe from meineke.
-Resonator delete
Current:
Older:
Fogs/Lows/Highs/Reverse all lit:
Climbed a Hill:
Now that I look at it, my tires don't look too aggressive... Hoping to get a fifth soon, as well as get on top of that FJ suspension install.
New Reverse Lights
I installed some 886 lights in my reverse lights today! Here they are:
I know the license plate light is out... It's a loose connection.
You sure those aren't 265/70/17s?
You're right, should probably change that...
Looking good so far, what else is in store?
I've got the FJ suspension still sitting in the garage, but I'm kind of split between going for the Toytec spacer up front or going Daystar 2.5/1.5. If I go the Daystar route, it may take me another or month or two to get the green together for it. From there, we'll just see how it goes!
Save up for the 2.5/1.5. Also, check the classifieds, you might pick up cheap set. Good luck! Your off to a good start.
MAJOR PLANS:
I think I'm holding off on my mods for a while... This being in lieu of a 4WD conversion I see coming this way. I'll be using an A750F transmission coupled to a VF2A manual transfer case from an FJ Cruiser. I'll be buying everything used/rebuilt other than the Front hub assy.'s and CV Half-shafts.
MAJOR PLANS:
Awesome! Can't wait to see the outcome
Got some goodies coming up pretty soon!
TRD Exhaust tip (Man, that was a ***** to find):
Borla ProXS Muffler:
Oh... and that box under the exhaust stuff... That's the FJ suspension that's been sitting in my garage for the past 4 months... Moved it to the basement.
First Towing Experience... Towed my friend's wave runner out to George Winter Park right after they got it running again:
Pretty eventful weekend.. Seafoam'd (Why didn't I get any smoke? :/ ), Changed oil and spark plugs, and going to paint bumpers tomorrow! And will hopefully swap suspension after I get back while the bumpers are off. May give me a bit more room.
Bumpers off!:
looking forward to what you think of the Pro x/s muffler... haven't seen anyone else with one installed to hear it as well.
Just sent a facebook message to a friend of my 'rents, who is a very passionate welder. So that should be coming soon, and even sooner if he has access to a pipe bender.
While my bumper was off, I decided to look into modding the red reflectors.
I opened up the area that, on the non-US models, is used for a bulb:
I then went to go pick up some dual filament bulbs:
My plan is to use these as more brake/tail lights, and if anyone has any input on how I should connect these to the brake light circuit, I'd like to hear. I do still need to order 7443 connectors.
i'd just get a socket and tap it into the tail light + shouldn't be too much draw coming from those little bulbs
2001ATL
