Stuck E-Brakes
I have a 96 4runner with a stuck e-brake. What is this easiest fix?
I'm not sure what I understand what you mean by "stuck e-brake". Could you provide us with some more information and I'm sure someone around here will be able to help solve your problem.
I'm gonna take a stab in the dark on the most common e-brake malfunction.
What happens alot, due to long periods of not using the e-brake, the levers inside the rear drums freeze. Sometimes you get lucky and they freeze open...but other times they will freeze with the brakes engaged, which is bad news.
If you go to your toyota dealership and tell them what the problem is, they will likely know exactly what you're talking about and what parts are necessary to fix the problem.
Basically you have to pull apart both rear drums, and all the brake hardware, unbolt the lever, and bolt up the new assembly (complete with new pivot pin and e-clip).
BUT FIRST make sure that this is the actual issue. Lay down under the truck, and on the back of the drum, towards the rear of the truck you will find the e-brake cable. Follow this to the backing plate where it connects to the lever. Try moving it by hand or a flat head screwdriver. If it doesnt move with a little effort, it is frozen and the above procedure will remedy it.
If the hold down springs broke/came off of rear shoes would result in the drums being "stuck".... seen it a couple times on Tacos.
Thanks- I loaded up the levers with WD-40 and liquid wrench, then kept working them with a pry bar and a hammer. Eventually, it unstuck and is now functional. I can know get it inspected.
Thanks again,
wperk
Damn, I'm good :trophy:
just keep an eye on it, as WD-40 may just be a band-aid on a true problem.
And use your e-brake every time you park, that's the best way to prevent this from happening in the first place (and it's better than the pressure on your drivetrain)
