studded tires
Don't have to make a mountain out of a mole hill. There are plenty of drivers (even women) who survive in the winter with rwd vehicles. Getting a 4wd it not a bad idea but there is easier ways. Give her a chance to get use to the 4runner, hell shes only driven it a handful of times in bad weather.
This is what I'd do to prep her...Get the best snow tires available, Nokian comes to mind. Put some weight in the back, don't be shy, 400-500lbs back there will significantly improve rear wheel traction. Take her to an empty icy parking lot and practice emergency manuvers. Those things should help keep her going straight, but its still up to her to drive according to the conditions.
Yeah i definitely like that idea. Next snow fall Ill take her to parking lot and let her get the feel of controlled wheel spin. Get her confidence up. that’s will help a lot cause I think she’s just scared more than anything
Just a quick note, i heard that BFG ATs are garbage in the snow? Mud tires shouldnt be used in the snow at all thats the reason i got General Grabber AT 2s they are snow flake rated and have the holes to be studded if needed. Siping is what you need to look at for ice n snow. Just used mine in NY/NJ snow for the first time behaved like a champ and yea change all 4 if ya do! (id look at some revo 2s as well they are supposed to be good) good luck.
Mud tires suck in snow due to siping. You get better traction from snow on snow rather than rubber on snow. Most BF KO's sizes are extreme snow rated and have the snowflake. They "get by" but I wouldn't get them specifically for snow.
Im in no way an expert but siping from what ive researched is what is needed for snow and ice. It gives the tire more gripping edges so the more siping the better! Mud tires usually suck because of too much space (which allows the mud to channel) or lack of siping. Fourms can be confusing sometimes lol.
How Do Winter / Snow Tires Work? - Alex's Automotive Performance guide | Tire Rack
Sipe your tires for better snow wheeling performance - SnowTrek.org
Siping (rubber) - Wikipedia, the free encyclopedia
Tire Siping - Discount Tire
I believe this is exactly what he may have meant to say or did say you just interpret it differently.
Thats a good find. I had no idea this is something that can be done.
Get Nokians or something with the same pattern. Studded if the vehicle is driven a lot at night. Black ice is nasty stuff. Consider 245/70R17 for stock height or 245/75R17 for a little larger than stock, narrower tires do better in slick conditions and will hydro-plane less in slush and standing water.
When placing weight in the rear of a vehicle for traction try to keep it close to the rear axle. If the weight is placed too far back it makes it harder to regain control of a sliding tail. Some bags of sand in the rear passenger foot wells would be ideal for weight distribution albeit inconvenient. When I ran pickups I'd put the weight in front of the rear fenders.
A winter or two with a RWD vehicle will make your GF a safer winter driver for the rest of her life. Very good experience to get.
tuṣṭāva
