Bftfan
I put on new pads & rotors last weekend and except for rusty caliper pins in front it went pretty smooth. Done lots of brakes in my lifetime this was just another one. Once I got it put all back together I noticed a faint "scrape, scrape" sound at the left-rear wheel and a definitive "CLUNK" when I backed up almost like something was binding.
So today I raise the the rear end and compare rear wheels. Driver's side clunks when the tire is turned and passenger side does not. I pull the rear driver's side wheel & caliper and it seems like the sound was coming from the E-brake. The E-brake shoes in here looked ok, no excessive wear or scoring on the new rotor. Pulled the rotor and backed off the star-adjuster and put it back on thinking this might be it and still getting a clunking sound from the hub assembly when turning the wheel in what would be reverse, even without the caliper & pads!! That old rotor came off easy and I doubt I damaged the wheel bearing in the process but I'm stumped! Any ideas?:sobbing:
Oh and I'm pretty sure it's not the infamous driveline clunk because I keel everything greased up real good and this is right at the rear wheel, only on the driver's side.
