Successful 3 button to folding flip key swap!
emmantik
Today I successfully swapped my 3 button key for a folding switchblade flip key.
See pic for key bought from Amazon.
Really simple swap. You will need to transfer over the button/battery pod from your 3 button key. Should just pop out.
You will also need to swap over the transponder. Its a small black rectangular piece with a slight angle on one side that is glued in place. I didnt have the patience to scrape and pry it out of the 3 button key so I cut open my grey valet key and took the transponder. Should just pop right out once you cut it open. Take the transponder and pop it into the flip key. There should be a slot for it which is obvious. The transponder didnt sit snug so I put some electrical tape on one side to fill the tiny gap to make it a tight fit.
Make sure the buttons on the flip key are in the same position as your 3 button key. The buttons came in the wrong place but they come off easily so you can put them in the correct spot.
Tip: there were some excess pieces of plastic on the inside that got in the way of the buttons pad. Just took a blade and sawed them off easily for a better fit.
As a side note. The buttons didnt feel as firm as I wanted. So I took some adhesive foam tape, cut them into tiny squares and stuck them behind where the buttons were on the pod. This allowed less wiggle room once it was all sealed up. Now they have a firmer/tighter feel when pressed and sit in place more firmly.
Tip: be careful with the spring, you could probably snap it if installed incorrectly. This part was the trickiest out of the whole swap but just be patient. The videos below should help.
From what I hear, some places won't cut automotive keys without a hassle. Luckily my local hardware store (Canadian Tire) did it without any questions.
I used the following 2 videos as a guide.
https://youtu.be/KlmjV7oRvlA
https://youtu.be/NNOkLgEDSvQ
Hope this all makes sense. Ill be glad to answer questions if anyone has any but it is really straightforward.
Edit: they didnt come with the logo so I found and bought these from Ali Express.
Sent from my SM-G930W8 using Tapatalk
Well this looks promising...just wondering, where did you get the key cut?
I got it done at a local hardware store. Easy peezy with no hassle. From what I hear some places wont cut automotive key easily. (Im from Vancouver Canada if that makes a difference)
As a side note. The buttons didnt feel as firm as I wanted. So I took some adhesive foam tape, cut them into tiny squares and stuck them behind where the buttons were on the pod. This allowed less wiggle room once it was all sealed up. Now they have a firmer/tighter feel when pressed amd sit in place more firmly.
My Volvo S60R had that style of key. I thought it was pretty cool at first. It soon became a pain in the but opening closing it every time it was in pocket. Also very big when in switch or pocket for that matter. Of course my LE is no svelte item either but at least it stays in the pocket.
The good thing about this swap is its plug and play. If I find that I dont like it down the road I could always revert back easily. The only thing Im losing is the grey valet key. I also have have 2nd 3 button key so Im not really losing much. I dont think I'll be swapping back though.
Has anyone successfully removed the chip from the 3 button key without destroying it? I use the valet key when I go surfing.
Has anyone been able to find a 4 button flip key to work with the 5th gen? I'd love a flip but also with the option to lower the back glass. If not, how is the 3 button holding up?
delislerebecca
