I don't have a leak, so I think I have a fuel pump or filter issue. Here is some background on my truck's most recent problems because it may be relevant.
If you can help me out with some tips then you'll have my thanks!
My 1999 4Runner has about 180k on it and recently I had a pretty bad leak fixed. The leak was from my cam seal blowing out so I also had them put in a new timing belt (which was due soon), water pump, crank seal, etc. as well as a fix a leak on the crank shaft case.
Anyway, I've had my car back for a day now and on the highway I noticed a pretty worrying drop in RPMs coupled by a oil light flicker and a sudden reduction in speed. These symptoms were almost exactly what I saw when my seal blew but this time I didn't bleed oil all over the road. The oil level is in the middle of the 'good' range right now and the engine starts up just fine but when I start moving the shuttering rpm movements come back seemingly at random.
I am thinking the oil light came on because of a drop in engine pressure from a lack of fuel getting pumped in. From what I hear this could be because of a clogged filter or a broken pump. I am hoping you'll all say that it is a my fuel filter which needs replacing because that is admittedly coming due soon and I don't know if I can swing the expense of a pump right now.
I live in an apartment and can't work on the street so even small repairs are expensive when I have to take it into a shop, besides I lack the knowhow to do most of the stuff you guys talk about here.
So what do you think, do I need a new fuel pump or just a filter, or is it something else entirely?
