Suffering search overload. Xreas and Fj Springs ?
Regarding the RAS and adjustment, I noticed no significant change in ride quality with the bags adjusted to ride about an inch higher than stock. I put a few thousand miles on mine and never felt it was impacting the ride enough to be noticeable.
With the Daystar 1" kit, expect to gain 1.75"-2" lift. It will provide more than they claim. This may be fine for you, but many think that's a little "too" level.
Thanks. Good input.
So I've been doing more searching mania on this and I saw a bunch of threads on the Daystar 1" producing 2" lift or similar, so that seems to be the consensus.
I don't want the "bro rake" e.g. neg rake. What about Cornfed 1"? I believe this is the unit on Burtman's site and they say it produces 1" actual lift. I'll get there yet... :confused:
The Cornfed lift will provide right at 1". Toytec also has a spacer that'll give you 1" and is a cheaper than the Cornfed. With the front suspension, you will get double the spacer thickness for lift. The Cornfed and Toytec are both 1/2" thick spacers. Daystar doesn't believe the 2:1 ratio exists so they advertise their spacers based on thickness (at least the 1" spacer they do, I'm not sure on the 2.5/1.5 kit).
Ambrose67
