sunroof drain cleaning
To the OP: I finally had to do this today on my 2012 LE. Thanks for the guide. It made the job super easy and I was able to finish up in 15 minutes.
The filter end is to keep animals and from going back into the drain. Next time it is clogged, take a syringe with some drain-o and let sit. Then rinse with hot water. Careful if you used one with bleach as it can stain the interior.
Do you squirt the draino into the drain from the top end and let it work it's way down?
I've been getting a puddle on the driver's side during very heavy rain storms and I bet this is the culprit.
I couldn't find much info about where the 5th Gen sunroof drains come out. I knew they came down the A pillars and somehow out the rear (Just like the 4th gens, there's one run through the tool area in the rear). My sunroof was holding water so I knew I had a clogged drain. Turns out it was 1 of 4 that was clogged the others seem to drain out of the pinch welds with no access to the "exit end" - Toyota this seems like a horrible idea.
My Front Driver drain was the one that was giving me issues so I spent a while trying to track it down. I had tried the weedeater string, and even a coated braided steel cable. It seemed to run the same length down each side before bottoming out so I wasn't sure what was causing the clog.
Once I stripped away some of the panels and electronics I pulled the hose out to find the small "filter plug" on the bottom. This is what was causing my tools to bottom out, and it's also what was causing the clog. Mine was packed full of debris. Figured I'd share a photo in case anyone else is having a problem tracking them down.
Thank you, I had a gurgling sound after rain and car wash every time i made a right turn. My passenger side was clogged, about 10 oz of water still in tube, last rain was 2 days ago. the other 3 are clear. Thanks again
wayblom
