Sunroof rattle only when shade is shut
ellroy2
Have had an intermittent rattle coming from the sunroof on my 16 4Runner. When it is happening and I slide the shade open, even just a couple inches, it usually stops. Then when I close the shade again, it usually stays away for awhile. It's not regular enough for me to take it in to the dealer because I know how that goes. But when it does happen, of course it is annoying.
My 08 4Runner had a bad rattle that I eventually fixed(thanks to this forum) by putting some little washers or something in the track somewhere. But not sure if this is the same issue or not.
Any ideas?
OP - I have basically the same 4Runner as you: 2016 TEP, KDSS, Super White and I have this same rattle in my sunroof when the roof is closed but the shade is open. When it's happening, I can touch the aluminum piece that pops up when the sunroof is open and the noise subsides. At first this only happened with cooler temperatures - now it happens all the time.
I have brought it to the dealer under warranty and they said it was normal and then pointed at my BFG K02 LT tires as being stiffer and the reason why. I wonder if something has to be tightened on the aluminum bar that pops up?
I didn't know sunroof rattles were considered normal. I guess I will have to go back and check the brochure to see if the rattle is a standard feature that comes with the sunroof or an added option that I paid for and I didn't know. Gotta love the dealerships.
Nice looking truck btw...
leolediola
