sunroof rear window auto problem, intermitent
iBison
Occasionally my sunroof and rear window will only operate when I am holding the button down. When I let go of the button they will stop moving instead of opening or closing completely. Once in a while the driver auto up/down function will have the same problem at the same time, other times just the sunroof and rear window. Usually after I have driven it a few times it starts working normally.
Anyone experience this or know what to check?
If you have changed a battery or disconnected you will have to relearn the system, just hold the button down for a whole up and down or open and close! That will reset the auto motion and you should be good!
Thanks! I did replace the battery a little over a week ago. It has happened in the past, but this is good to know.
