Surgeing RPMs when rolling to a stop
Gerdo
A new issue. When I'm rolling to a stop, with the clutch pushed in, the RPMs surge up and down from 1200-2200 RPMs.
Any thoughts on why?
The RPMs calm down after a second or two once I come to a stop.
I'll have to check for a vac leak and the coolant level.
Being a manual transmission, you have to check the dash-pot on the throttle body. Check the PDF..
A dash-pot keeps the throttle plate from slamming shut on decel, allowing it to close slowly to reduce emissions
To find a vacuum leak you can spray "something" on the lines while the engine is running. When/if the engine stumbles, it's sucking the spray into the leak/engine. I'm trying to remember what spray to use. I don't want to destroy rubber or things from the wrong spray.
Anyone know what to use?
Usually carb clean
Everything checks out fine. Nice thoughts.
I'm going to have to do the vacuum line check again. Maybe I missed something. I did change out my IAC but it didn't change anything.
